41 - 60 of 73 Posts
post
post more videos of the turbo caprice!!
Discussion Starter · #43 · (Edited)
lol, were aiming for more then just 450 dan!!! the turbo is rated to about 620fwhp so were gonna push it as much as we can, hopefully 550 at the wheels. just trying to source out a good trans and some bigger injectors.
the interior is all apart as were swapping in the ss interior, as soon as its finished and the rain stops will post up another vid or two.
those are some hi goals for a stock engine with a rear mount the f-body guys have been struggling to make that kind of power with rear mount kits for years now since squires first came out with these kits.
550REAR WHEEL or at the flywheel?cwm3 or did i read this wrong and you are speaking of this type of HP levels once the 383 is in :D.
edit: just saw your pics of the new engine yeah those number should be right around that area.sorry to doubt but i thought you were talking 500+ horsies with a stock engine and just 1 rear mount.
your build is looking good bud more vids and pics i am fully subscribed now.
Discussion Starter · #46 ·
well started the swap this weekend,
out with the old:
new:
parts swap:
oil and auto trans cooler delete...
in with the new:
mcleod twin disk!!!???
LOL
Discussion Starter · #48 ·
lol yes takes care of my transmission rebuild dilema...
Discussion Starter · #50 ·
Well it's a m28 93 trans with 373s so essentially a 456 lol. No turbo lag here....
WOW! I thought i subscribed to this thread. I guess not as I have missed quite a bit. So how is everything working out Roy? You certainly didn't waste anytime pulling the stock engine and tranny. i just wish you had done that before we did the kit so we could have pushed the boost and shown everyone what a single rear mount turbo system is really capable of. :)
For those subscribed and those specifically waiting for a progress report on the twin, rear mount kit, we are working on a custom version right now. The air filters will be located in the trunk. Down-pipes will route under the axle, to the stock resonator location and out the back. It will look like a dual 3" exhaust from behind. :) we are going to try and make this kit work with our 2" primary "Pro Series" headers. When this project is finish i will start a new thread.
Dan,
Do you plan on marketing the single STS turbo or just doing the twin turbo?
Dan,
The single has been available for quite awhile now:
http://www.clearimageautomotive.com/STS Impala single turbo kit.htm
There are many choices based on your taste and goals.
Send me an email with your specific goals, the type of activity your car is used for, choice of stainless tubing or aluminized tubing, etc, etc. I can make some suggestions and send you a quote.
Thanks for your interest.
Thanks Dan! I looked on your site but missed it somehow. The price is reasonable too!
Discussion Starter · #57 ·
hey dan finally got it in and initial start ups, here are a few teaser vids. recorded on my iphone, so please dont comment on vid quality people.....more info and pics and vids to come, this was just to test a few things out....
first run was just to test out the t56, and 383, havent been ran in over 2 years, 1/4 throttle
2nd run is about 1/2 throttle, no where near its potential yet!!!!
sounds like were building boost at idle, lol, sounds like a jet!!! dan we will need that twin turbo charge piping very soon!!!!
Discussion Starter · #59 ·
Thanks! Also Dan I think it was a good idea to do a base on the stock combo to show people what it can do on a stock motor. Now we will see what it does on a 383. For mods the cam is the cc305, heads are fully ported afr 190s with port matched intake, bbk 58mm tb, 1.6rr.
I do think were gonna max out the single with this combo and the twin set up will be needed. But that will be the fall/winter project.
Nice job.
As for the boost tubing. Here's the deal, the twin turbo tubing is set-up to work with small turbo's smaller flanges, etc. There is also a difference in the way the turbo's hang under the car as compared to the larger, single turbo you have. We will be able to get you close but you going to have to do some custom fitting/welding on your end to get the exhaust to match up to the large turbo's you want to use. Keep me posted.
Also, yeah, it will be nice to show people what the same turbo kit does ona bone stock car with 5 psi and a built motor with 15 psi. i don't think many people understand the HUGE difference there is with 10 psi on a motor built to handle it.
41 - 60 of 73 Posts
