1 - 10 of 10 Posts
Hey guys, sorry I'm new and this is my first post.. So far I've read a ton of threads relating to my issue and have done everything to diagnose the problem however, I am still stuck.. Also don't know much but trying to learn how to work on a cars so kill me. Willing to learn.. ok. So cooling fans aren't working.. Fans work when I jump them from the battery.. Relays are good… Fans kick it when I unplug them from the CTS after about 20 sec like it says on the posts… My car runs hot only when I'm in traffic and stop as no wind is hitting the radiator.. Fans DO NOT come on when I turn on my a/c. A/C even on cold is always hot.. Whats my next move? Is it a faulty CTS? Is it wiring? Is it me? Taking her on her first road trip this weekend and do not want the car to overheat if I am stuck in traffic. Has new radiator new upper and lower hoses. Didn't know what a thermostat was when I flushed the old radiator fluid but now I do and willing to change if needed but I do not think that is the problem.. Thanks guys. :cool:
Make sure there is no air in the system. Did you berp it after you put new hoses and coolant in? Also ac needs to work make the other fan to kick on. Also you should get your pcm tune for lower temp and change the Thermostat to 160.
THANK YOU! No I did not bleed the system after so I will definitely do that! I will charge my A/C as soon as possible I will be looking through the threads to learn how to do it! Thanks man.
Does your car actually overheat, or does the gauge just climb? Factory gauges are generally not that accurate. Actually measuring the coolant temp would let you know for sure.
On my car, the coolant temp sensor was bad(reading low), so the fans wouldn't kick on until it was way, way too hot. Comparing what a scanner said the engine temp what to what I actually measured with a temp gun on the upper radiator hose showed that the sensor was off by more than 50°. Replaced the sensor, now the fans work as they should.
Hey Bugman, no the car doesn't ever go into the "overheat" or red portion of the gauge. It kind of irks me however, my main concern are the fans. They never come on, not even when I turn on the a/c. I've read that once you turn your a/c inside, your secondary cooling fan should turn on and the fan doesn't turn on. Thats my concern. Getting the cooling fans to turn on. The dude from above suggested charging the A/C going to buy the supplies to do that soon.
The fact is that with the factory turn on temps, the fans hardly ever come on anyway. You must get the PCM reflashed for lower turn on temps.
The odds are against you that the A/C system only needs a charge. Take it to a shop and have them determine what is wrong with it before you waste a bunch of money on re-charge kits and having them not cure the problem.
The other tests you have done have confirmed that there is nothing wrong with the fans or relays. Good luck.
Hey Fbi9c1, thank you for replying! I see your post everywhere I appreciate the help. Yea… I think I am going to do that… My condenser looks like **** and the previous owner, I'm sure, didn't bother changing it, big possibility a leak might be there. There is a male end of a cable there unplugged.. Can't find somewhere to place it going to try to read more on it but thanks for the help man.
Jackfish, it does have a a bleeder valve on top of the thermostat housing. Why do you ask?
1 - 10 of 10 Posts
