L
Is there anything special that would need to be done to install a sub and amp in a 95 9C1 with the stock radio?
Does the stock unit have a pre amp output?
THanks
go to walmart they have a rca line converter its about $10.00 i got one the other day waiting on my amp to come
you can hook up a amp to the stock radio, the radio does not have a pre amp out put, buy the rca line converter like sspecial mentioned, the remote wire from the amp, can be tap to the radio power antenna cable, even if your car don't have power antenna, your radio has a out put for it. an the rest is just running wires.
For the same price as the converter you can get a specific crossover for subs which has frequency adj. and bass bost for about 10 bucks off e-bay mine is a pyramid cr66.
It has rca or speaker level inputs.
Another company makes this part because about 5 places including radio shack/optimus have the same part with a diff logo.
heres info on the pyramid model http://www.pyramidcaraudio.com/itempage.asp?model=CR66
