1 - 20 of 27 Posts
P
I am looking for a cutting templete for a sub box for a Caprice. I been looking for a idea for a custom enclosure for 2 kickers sub boxes. As you can see in my cardomain that I have a lottle system however i am looking for a cleaner look. I like the subs in the side walls, so I can keep my spare. However i dont need the spareif you have any ideas that would require me to take out the spare.
Thanks.
Here is an idea that I was going to do. It dose take up the space where the Spare tire goes. There is a thread here about it do a search.
Ok Morning guys. have a question about the box in this thread. Do the holes have to face as they are or can they be placed forward on the thin side??? anyone anyone anyone Buller
1
i wouldn't suggest that it will sound much better the way it has been designed if you are looking for a stealth look you could prolly do a false wall over or if worried about puncturing the subs place grille on them
there is a pre-fab box that will fit and looks like that one. it is a box for a camaro. the camaro has a drop down hatch area, this box fits very well, I had one in my caprice. I just switched to a mini spare to save room.
N
That box actually has about 2 cubes on each side, not including the ports, so be kinda careful, some subs require less air than these boxes give and some require more air than these boxes allow. I wouldnt put the sugs on the 7.5 in side, who has subs that small anyways, but the top is doable, if you double the thickness of the mounting face... which would make your box have a volume of3.8 cubes using 3/4 mdf and double on the face.
Keep in mind, how much air you need depends on the sub, so check ya data sheet first, then design a box, check it 3 times and then start building.
I have done 3 different boxes just like you said. Space is very hard to come by in the side panels so choose your subs carefully. I believe if you search on my member number in the car audio section you should be able to find some pictures. My first box is shown on my website and it is very outdated, but at the bottom of the page you can download the plans to build them. Just click on the link below and go to the Sub Box area.
http://home1.gte.net/bristra4/index.htm
Let me know if you have any more questions,
TOM B
Here is a 1.3 Cu ft, ported, 12" bass guitar cab I built nearly a decade ago, and use professionally on a regular basis.
I've also used it as a sub, in a pinch, for "tail-gate" parties. Works great for that as well...
The port can be adjusted in size, or completely closed. The box freq is about 75Hz with the larger port, and about 53Hz w/the smaller port, 52Hz with a touch of EQ. Though smoother and producing lower notes without a port, the sealed cab isn't as loud (efficient) at the frequencies needed for bass in a car.
I have found, however, that the size and shape of a ported cabinet dosen't matter as much as the cubic feet of air space in the cabinet, and the tuning of the port(s). It can literally be made to fit almost anywhere.
Personally, I prefer the smoother sealed cabinets (except they require more power). But for a specific range of bass frequencies, a ported cab is easier to build and tune.
[edit: BTW, nice sedan sub boxes, Tom!!]
1
has anyone here actually made this box:
because my car is in storage wondering if i can make this based on exact demensions and not have to worry about it fitting.
Discussion Starter #13
I am making one right now the measurements are correct.
Discussion Starter #15
That is my design. When you make it watch out for the depth of your 6x9. I never used the port hole because of not enough cubic space. So I made it a sealed box. Old pic Old pic 2 The sub are diamonds 15's I have a new set up and will post pick soon.
Discussion Starter #16
Getting ready to redo this in leather and fiber glass. Running two 15in diamonds at 1ohm each hooked up to two Alpine M1005 amps. Amps pictured are old 600 watt kenwood amps.
[/url] [/IMG]
1
Discussion Starter #17
[ 02-25-2007, 07:08 AM: Message edited by: McGinnis88 ]
1
Discussion Starter #18
could you measure the clearance from the the top of the sub box to the rear deck i have some pretty beefy 6x9's going in. and also could you get me some dimensions of those hinge covers?
how much did materials cost?
E
Discussion Starter #19
[/url] [/IMG]
That's a real nice set up. I like the Supaman look.
Discussion Starter #20
Just to give you an idea my box just touches the bars that go across to help open the trunk. I will get the measurement soon.
1 - 20 of 27 Posts
