1 - 20 of 48 Posts
So Sunoco has decided to drop Ultra 94 in this area (Dayton, Ohio) I have been running it the whole time since I've been modding the Caprice and ain't sure what is the next best fuel I can or should be running. The next best "pump gas" is either Sunoco 93 or BP 93.
Have I been wasting my time trying to get 94 and will I loose any power with 93 octane?
Anybody had experience with this situation? Thoughts, Ideas?
I'm not running any cats and the track sells real race gas and I could "add" a few gallons to the tank but I sure wouldn't run it "straight"
they pulled it here in toledo too :(
So Sunoco has decided to drop Ultra 94 in this area (Dayton, Ohio) I have been running it the whole time since I've been modding the Caprice......
OK............so why do you need 94 (or 93) octane fuel???
KW
Unless you are tuned to run premium you are just throwing your money away. Higher octane does not mean more HP unless your engine is tuned for it. If you are running regular gas with no pre-detonation then you will gain nothing by running premium gas. If you do have a premium tune you should be fine running 93, race gas would definately be a waste and could harm your motor. But it would smell GREAT!
Discussion Starter · #9 ·
KW
I'm not tellin' :)
The car has gone 13.teens but usually in the 13.20s low .30s...
Mikey (1 fast94) See ya at the track, it's the last points race but my semi retirement this summer really put a hurt in my quest to be track champ'een in the sportsman class. Hey I did better in your class last time I raced running both street & Pro but without an electric fan to get her cooled quicker she sure don't like to be hot lapped between runs.
Time to get "Grampa's Limozene" ready for battle.
1996 BBB
Running higher octane (slower burning) gas can lead to unburned fuel fouling plugs. Running leaded gasoline, as it was stated his race gas is, is also not recommended in a stock LT1.
I never really got the idea that race fuel 'burns slower'. Higher octane resists detonation better than lower octane, that is what octane is essentially a measure of. But how does that have any affect on burn speed? I always figured perhaps this is flatout untrue, as octane rating itself, as defined, has nothing to do with burn speed, but maybe lead vs unleaded affects the burn speed?
Please....for the 3rd time.....answer this question.
As stated above, you only need it if you have had your car tuned for it. That means not just engine mods, but also you had your computer programmed for it.
In otherwords, if you have a stock car, you're fine with 85 octane. You will NOT see any benefit with running a higher octane.
Stupid me, just before the gas prices jumped had PCMForLess tune my computer to 91 octane. Sure, I get a bit of a performance boost and a bit better mpg... But the cost per gallon offsets the increase in MPG. If I could go back, I would.
KW
I'm not tellin' :)
Those times indicates that you're not running much static or dynamic compression; and as such, 94 octane could be doing more harm to you engine (and wallet) than good.
I never really got the idea that race fuel 'burns slower'. Higher octane resists detonation better than lower octane.....
It does that by......ok.......ready for this.......burning slower ;) .
KW
Once the air/fuel mixture ignites, it explodes. Tell me more about these 'slow' explosions.
...race gas...could harm your motor.
I know lead is bad for catalytic converters (which he claims he is not running) and oxygen sensors, but what would it harm in his motor?
As has been asked several times before, why does he need 93 or 94 octane fuel? Or race gas? I get no spark retard at the track with my 11:1 383 using 93 octane unleaded.
You too KW. Explain the concept of slower burning fuel.
In a way, is the same combustion principle (hi-octane vs lo-octane) as gasoline vs diesel.
It's not about the 'explosion' as you incorrectly phrased it......it's about what it takes to ignite and burn the fuel.
Read and learn.......these explain it a lot better than I have the patience to.....
http://www.wanderings.net/notebook/Main/IsHighOctaneGasWorthTheMoney
http://www.performancecar.co.nz/art...ffect-ignition-and-what-fuel-should-i-use-137
http://auto.howstuffworks.com/fuel-efficiency/fuel-consumption/question90.htm
http://www.petrolprices.com/about-fuel.html
KW
1 - 20 of 48 Posts
