Subject line says it all. I've had this transmission for a couple years now, but I only have about 11,000 street miles on it - no abuse, never raced. Just wanted a solid reliable transmission to support my mildly modified engine (227 cam with supporting heads/valvetrain mods, tri-y, catback). Like I said though, never abused. The TC was a little weak for it - a higher stall would be better (and is happily on order - btw, Shane - is it shipped yet?), but that was it. So anyway, I'm on a trip out of town, driving all highway miles - get into town at the destination, come to a stop light, and it's just a dog to get going again. I also noticed it never shifted as I got back up to speed, so I think it was stuck in 3rd. I go through the gears and it all seems to be shifting fine, so I figured it's just a one time fluke. Next stoplight, it does it again. Conveniently, there's an autozone right there at the intersection, so I pull in as gingerly as possible. It's just dragging going anywhere - lots of throttle to get anything out of it, so I'm basically just trying to get it stopped as soon as possible. I pop the hood, and there's smoke. Looking at the engine from the front, it's coming from the left side (pass. side), at the very back of the engine. Under the car, I can see more smoke. I pulled the transmission dipstick, and smoke is coming out of there too. Oddly enough, the stick looks more dry than normal, but it still shows fluid in the holes - it just looks different. I check fluid regularly so I know something is unusual about it. I go into the autozone and get a quart of trans fluid and a bottle of lucas trans fix additive. I add some fluid and idle the engine. No smoke coming out at this point. Everything looks good. I add more fluid a bit at a time until the dipstick looks more normal. I run it up and down through the gears, no smoke, everything looks fine. I close the hood and the doors. Then I realize the engine is running, the doors are automatically locked, and I have no second set of keys. Fortunately again, right across the street is a right-aid, so I run over and get a coat hanger, and reopen the door. I run through the gears again, check the fluid again. Fluid looks ok, gears have a bit of fluidy swishy sound to them momentarily. Hard to be sure exactly what that is. I try to see if it will move at all - put the car in reverse, and back out. Seems to go fine - maybe a bit more revs than normal. I switch to drive, and it's an absolute pig again. I'm not going anywhere in this car. And now, it's smoking bad. I've only moved the car maybe a total of 15-20 feet, and I can smell and see smoke even inside the car. It's not going anywhere. So I call AAA and they send out a truck. I need to move it one more time about 20 feet to get it in place for the truck (pushing would have been impractical). It almost doesn't even make it. So, that's that. AAA tows up to 100 miles, and my grandparents house was 89 miles away, so thats where I sent it. I deploy in 2 weeks, and since they had offered to store my car while I deployed, it seemed the logical thing to do.
[rant]
This damn car has been infuriating lately. Since the great rebuild it's been nothing but trouble - and I only rebuilt it to ensure it wouldn't be anymore trouble. 11,000 miles ago I had the engine rebuilt (roughly 190,000 on it). Had a 227 put in, but also beefed up the bottom end, and slightly improved the heads. Also rebuilt the rear suspension, transmission, brakes, new paint & bodywork, and fresh interior. Since then I've also rebuilt the front suspension again. So, about 6000 miles ago, the heads went (on a long trip). broke some springs and pulled a stud. I responded by going medieval on those heads. Completely reworked them with brand new parts all around, screw in studs, dual springs, guideplates, roller rockers, and a ton of machine work to match. Next, about 4000 miles ago, both electric radiator fans went more or less simultaneously - in the arizona desert no less. That at least was an easy fix. About 1000 miles ago the distributor went - again, in the arizona desert. Very expensive repair. Now, this. I have sunk so much money into this thing it's disgusting. It was my first car, and I've had it since college, but enough is enough. Maybe it's time to put it out to pasture.
[/rant]
So, what should I be looking for in the tranny? I can't believe a proper CPT tranny would fail with only 11,000 easy miles on it. Only recent changes made to the car have been the exhaust system - headers and cat back about 700 miles ago.
[rant]
[/rant]
