i am having suspension problems on my impala. i don't know why, but the car sits about 2-3 inches higher on the left than it does on the right. it still rides the same. Any suggestions? thanks.
You either have a bad spring or bad body bushings. Check to see if it is your frame that is off center or the body.
I would think that if the body bushings were bad you would notice it but not the case with worn out springs.
