·This past weekend I had the opportunity to borrow the drive on scale from work (used to weigh Airplanes) and measure corner weights on my 96 Impala. I would say that weight wise mine is typical of most "street" class Imapala SS's. I would say that these figures should be close for a large % of the cars.
Weight wise: HA bars front and rear, extra 23 lbs in trunk/package shelf. misc. odd 10 lbs. scattered in mods.
Car was weighed 4 times with 3 load cells, 4th tire was leveled with board. Averages are listed below (in pounds).
Car was weighed in Auto X set-up. Glove box and console empty, trunk empty (no spare, etc) tire pressures set, seat adjusted accordingly, FULL FUEL and fluids full.
LF: 1183 RF: 1163
LR: 922.33 RR: 943.67
Front Weight: 2346 56%
Rear Weight: 1866 44%
Left Weight: 2105.33 50%
Right Weight: 2106.7 50%
Total Weight: 4212
Same as aboveexcept with driver, helmet and 6 point harness (+230 lbs)
LF: 1283.67 RF: 1180
LR: 995 RR: 983.33
Front Weight: 2463.67 55%
Rear Weight: 1978.33 45%
Left Weight: 2278.67 51%
Right Weight: 2163.33 49%
Total Weight: 4442.0
Observations: 4400+ lbs is a HEAVY race car!
55% of the weight is on the front wheels - aluminum heads and a rear mounted battery would go a long way to evening things out.
It is interesting that right at 75% of the drivers weight is carried on the left side and that 51% of it is on the front wheels.
(My car has stock springs - this would change with different springs)
I hope to get some spring dimensions and some loaded height dimensions to better look at spring and shock changes/alternatives.
LF: 1183 RF: 1163
Total Weight: 4212
LR: 995 RR: 983.33
