D
got a police package 93cap,its being smoothed, painted, interior redone, 20 inch thangs, sequencialed, wig-wagged, tinted...you name it, im tryin to get it done and almost finished. Here's the fun part
My 93 makes awful sounds when turning and it bounces to much. Any advice(well alot I should say) is needed here and much "CAP"preciated.
As for the bounce, you didnt say if the Cap was lowered, and if so how and how much. You may be low enough that you are bouncing off the bump stops. Or if you have cut springs it may give you that ride, among other reasons, ie. shocks. The B-bodies are known for making a popping noise when making a full turn. I believe it is a ball joint issue. You can do a search and find tons of info on this.
D
everything under the car is stock I guess...nothings been done to it on my end atleast not yet.
