The main nuisance I found was that you had to move your seat back, tighten the belt/ knot it and then move your seat forward for the super snug fit, I could never get it snug enough without having to move the seat. It's not a big deal but it can be tedious if you a few sessions in the day and your seating position slightly changes each run.Some simply tie a knot in belt.
These B bodies have Barcalounger's for seats so if one intends to get aggressive autox use and stay put ... than a 5 point belt system at a minimum but better yet with a race seat.
I get that some people want to keep things as OE as possible - although I tend to disagree with them where LT1 cars are involved.It's all about the trade off between street and track usage.
If I find if I that I have to modify the seats, add a cage then you know I might as well get a car more fitting for the job 😂.
So I've kept my limitations to keep the car as streetable as possible, stock interior, exterior.
Just to chip on the experience with the smaller bar in the rear and bigger bar up front.
The car would grip a lot harder, as in to get the rear out during a turn I had to be on the accelerator quite hard. So I can see why especially on larger tracks it would be beneficial to do it because you're not hitting mustang type oversteer that quickly at high speeds since the turns on larger road courses won't be as sharp negating the need for that stiff of a bar in the rear.
However two issues with my application,
My autocross series is very tight so you kind of need an on demand turn-in type deal, and I do think it can be done with even a stock bar in the rear, however without bucket seats/harness you cannot physically stay put making it a very bad experience.
Stock seat and belts even tightened very hard I'm getting thrown left and right even though from the footage I've seen of my car it doesn't look like my car is rolling that hard.
The session I had two weeks ago with the BMR rear bar and 750 springs up front felt the best just because my physical self wasn't moving that much and I felt in control for once 😂. This Saturday with the alignment I have now I'm curious to see how the car handles because the alignment I had when I first tried it two weeks ago was fairly off.
Just straightens out very nicely
I would love to dwelve into the axle mounted bar deal but I got a ton of stuff to address before hand.
All poly in the rear (old rubber in the axle housing), extended fix length control arms, no DMR braces, old bushings and balljoints up front on the control arms.
I've got some ways to go to make it more ideal...
Great input Toonwarrior.Just to chip on the experience with the smaller bar in the rear and bigger bar up front.
If it's coming with the kit your installing then definitely run those, since you can adjust spring rates with your coilovers, the bar size is going to be less of a deal it is then if you would have with a regular coil spring, with a regular coil spring other than swapping out the whole spring or cutting it down we can't really adjust the rate so the significance of the sway bar size is higherGreat input Toonwarrior.
This made me re-think everything for my daily driving. I was thinking of going with the sway bars that included in the QA1Level 2 Kit. Do you have any experience with those?
