·is there really any difference between an impala,9c1 or caprice sway bar besides thickness or size. do any have different handling aspects?
The civie caprice has the same bars of the impala if it came ith an LT1, at least mine did.Originally posted by lilronjohnson693:
the civie caprice has thin sway bars which doesn't handle well, 9C1 sway bars are the best because they are alot thicker. I think Impala and 9C1 use the same sway bars. Caprice, impala and caprice sway bars all bolt up the same
My FE1 Caprice didn't have a rear bar either and it would lean around corners like it was it's job. lolOriginally posted by MrCadillac (Magnum):
neither one of my FE1 roadys had a rear bar. and both had the weak front bar... But my caddy had the thicker ones, along with slightly stiffer springs.
