Well I think I found that clunk noise from my driver side front that I've been hearing/feeling.
Looks like where the control arm connects to the front sway bar.
Is this as easy as replacing the missing bushing? Or would I need to replace more?
Glad I went ahead and got the bolts too.Do you still have the stock swaybar? If so, I'd just get a new pair of stock bushings. They'd be about as durable as anything else you are gonna try.
BTW, be SURE you REPLACE the bolts that hold the bushing brackets to the frame. They are a torque to yield design, which means they are usable ONCE. If you try and re-use them, it's a good way to strip out the threads in the frame. Then you have a REAL problem![]()
Ed
So you're saying this just might be the excuse I've been looking for to break out the old nut buster.The bolts have prevaling torque nuts on them, and they should only be used twice. You usually need an impact wrench to remove them because of the length of the thread. The bolts are standard bolts, but may not survive the removal of the nuts. It may be easier to use a bolt cutter to sever the bolt, and just put the new ones in. The bolts can not be torque to yield, because they are not in a tension only application. The nuts are run all the way to the end of the threads, and partially compress the bushings.
