1 - 13 of 13 Posts
I am missing something here. I have my aftermarket tach installed in my 96 Caprice. I ran the lead for the tach signal pick up to the main PCM. As according to another post, I opened the RED harness and went to pin # 13. But, number 13 already has a white factory wire in this spot.
What gives? Any other ideas?
Regards,
Matt.
Ok mine has the wire also, I tappd into it and my tach reads funny numbers.
No were near what it should.
Also when I step on the gas the shift lights comes on and stays on till I let go??? Don't know if that's b/c its an auto :confused:
PLZZ HELP THANKS:)
PLZZ HELP THANKS:)
Sounds like you have the wrong wire, possibly the shift light wire. may want to double check your hook up
I ve hooked it to the wire from the pcm and mine works fine.....I thought the 4 cyl mode is only on Impala ss, but I could be wrong.
Not trying to thread jack but I have a 95 caprice and it won't read any rpm and it's hooked up to the PCM which had worked for awhile but just quit
I meant the tach is wired to pin #13 on the red side witch it to the tach pin. I also turned it to the 4Clyd it still no change. :(
Make sure you have good power not just to the dimmer but the red power wire to
1 - 13 of 13 Posts
