Hey i am putting in a stereo and had a hangup when taking off the faceplate on my 96 impala. I got the 4 screws on the bottom of the drivers side and the screw under the fuse slot. and in the tray area i got the four front facing screws and the one upper facing screw. also a few under the tray area.
Do i need to remove the cluster cover? and because its hanging up around the steering column and I can't find any more screws.
Travis
once you take the 2 screws out of the black peice around the guage cluster, you have to pull fairly hard twards youand it will unclip. once you do that the entire lower dash should come off. and i think you have to have your glove box open when you remove it.
