yeah
After looking at it yeah
ok I have a 1993 RMS and I was wondering if they had any CAI options. I have looked and looked. If anyone has created one for there car I'd like to see. Also is there anyway I can do away with the TBI. Or would I have to do an engine swap found a ls but is it going to be worth it.
If you look at the factory setup, It pretty much is a "Cold air intake"
Cut out the restrictive metal support bracket in the air box that is viewable when the air filter is off (Just leave the ends where the threaded rods go through for support) It made a nice little improvement on my wagon 10 years ago. File the edges down too so the wires cant get cut on it
You can use the caddy hat and pvc tubing with a cone aircleaner by the DS front at the charcoal canister. That is done a lot. If you need the caddy hat, I have a couple with the flexable connector, bent stud, and nut. You have to supply the pvc and air cleaner.
