·• Substitute Billet Superlite Six Calipers $225
• Substitute Drilled Rotors $125
• Upgrade to Superlite Six Calipers $595 plus pads
• Stainless Steel Shim Kit
(Incl. 6ea 010/.015/.030 shims for perfect caliper placement) $15
• Gas grooved/Slotted rotors $55
• Pad wear spacers for longer pad life and piston trueness $25
• Zinc plating for rotors $65
• Drilled rotors $125
• Custom powder-coated finishes $70-$120
• Substitute 5/8" ball joint spindles- special run fee $75
Options you recommend? What pads run the best in the rain?
thanks in advance
thanks in advance
