1 - 20 of 118 Posts
Restarting the Soft 8's thread!
If you're rocking a set of Cragar Soft 8's, post em up! I'm interested to see a set of 17s, hopefully some 17x10 rears on a wagon! I'll post up some better pics of my 15s once the thread gets goin..
BigBody, Sweet looking paint scheme. It looks sharp.
How big of 15s and tires can be stuffed on the rear of a 95 wagon without cutting?
theres a guy on here who i got my idea from.. he was running 15x10s in the back with 6 inches of backspacing, which is the backspacing i plan on running. i plan on doing the 17s/springs/shocks for my birthday.
anyone got ideas for a tire size on 17x9s? i wanna upgrade to a set but i also want some RWL. any size that does this?
The widest you could fit is a 285/40/17 on 17x9. You might be able to fit a 295 series tire out back, but I'm not sure if they make these for the 17's.
hope these help a little.
15x8's (4"bs) w/235 60's and 15x14's:) in the rear (7"bs, 1/2" frame notch) w/ 295 50's also 2 pics w/ 15x10's in the rear (6"bs) w/ same 295's. P.S. the 6" bs is perfect w/ the 10" rims but NOT with the 295's! No spacer, the tire hit the frame and w/ 1/4" spacer, the tire hit the skirt even with the lip rolled. Hence the flares:) 275 60's would probably be o.k. though.
I still have the 2 15x10's if you are looking for some (I wouldn't want to go that "narrow" again:)) Depending where you are though, shipping would be pricey!
mines on 17x9.5
No such thing as a 17" white letter tire for cars. Just trucks... although I bet you could noodle around and find a White letter SUV tire that does work...
What offset are you running on those 15x8's, anyway? I gots an idea... gonna play with some centercaps...
Anyone got these is anything larger than 17s?
The widest they make these in a 17 is 9 or 9.5" 17" is the biggest they offer the soft 8's in. They also make them in a 17X8. My plan is to run 15X10 with 5.5" backspacing and a 275/60 drag radial and then 17X8 up front to clear my C5 brakes.
I was also debating getting a set of 17X9's for the rear to use as a street setup and run a 275/55/17. Mainly because of my TH400 and a 275/55/17 is pretty close to the same height as my 295/30/22's
Summit will do custom backspacing on these wheels for an additional $20 or so, so don't feel obligated to get a standard made size when you decide to order.
1 - 20 of 118 Posts
