Are these little plastic ends the cables coming out of suppose to be tight or snap to the base, mine are just kinda loose
Also having a helluva time get the other 2 throttle brackets bolts in, weird angles
If you mean the dust covers on the cables(yellow circle), yes they are a little loose. The cables should snap into the bracket and be fairly tight. If I wiggle the plastic I can see a very small crack between plastic and metal.(red line)
I think the cruise cable is loose until activated. If you have a lot of slack in the throttle cable there is a quick fix but no factory adjustment.
