I have a 91 caprice i put new tie rods all 4 drag link pitmen arm and both lower ball joints and the steering still has some play in it about 4-6 inches i was wanting to know if anyone knows how to tighten up the gear box on the caprice.
What shape is your collapsable intermediate shaft in? The rag joints could be part of the problem. Jeep Cherokee (boxy ones '93 and earlier) intermediate shafts are a cheap fix. Check them for play in the universals before using (they will click when twisted, if worn). It is a bolt in after loosening the sliding shaft. Even a worn one will be better than the rag joints. If you have a substantial budget, there are other options: after market steering box, and collapsable shaft. If you really want to spend some money, I saw a rack and pinion that could be adapted.
i put new everything on the front end the steering shaft u joint is tight very little play the box seems to be the only thing loose
