R
i have a 95 9c1 with the impala ss 17 inch wheels when i turn the car all the way to the right i notice a wabble of the tire so i check it out and found out that the trie was rubbing on the stabilizer bar when i turn it all the way to the right,the left side rub a little but barely,what can i do to solve this problem
A stock SS will do that. You can get bigger steering stops but they will change your steering raduis negatively. Most of us just live with it.
R
thanks Dwayne!what about a wheel spacer,another stabilizer bar, any one with other idea
Most other bars will be thicker and still rub, I have no specific knowledge of any that do not. Good spacers will cost a lot of money. There is still the steering stop option and those are a GM part.
The only problem with the rubbing is the shiny spots on the bar and in my case on the frame behind the a-arm. Mine has rubbed ocasionally for years and there is no damage to the tires. I put a lot of miles(86K in 3.5 years) on and use those tires and rims April thru October.
Why are you so worried about fixing it, just a damage concern, or is it something else?
R
i just wanted to know if it would cause a problem or it could be fixed.pluse it seem like this disc is loose i tighten the lugs but it still lose, i'll have to look at it again tommorrow
Rubbing will cause no problem.
The loose disc thing is not fixed by tightening lugs, under the cap on the center of the rotor is a nut that needs tightening, your wheelbearings are probably a little worn and this will take up the slack. From your post I gather that you are kind of new to mechanics so I suggest getting at least a Haynes manual($10-15) for the car the factory service manual is better but cost a whole lot more like around $100. This will give you good instructions on how to tighten that nut, while you are there you might consider repacking or replacing the wheelbearings.
What helped me when I was in that situation was......This Forum.. I have learned, which I knew nothing about, tons of things. Once I read certain posts, things began making sense. Now, I am not a die hard mechanic, but this forum let me save $$ on:
Changing my WP
Changing the radiator
Lowering the SS
changing the serp belt instead of buying a new ac compressor when it was squeaking.
etc.
The forum has also cost money though:
Smokeys carpets,
Lowering Springs,
Bilsteins,
motorvac,
down to a red bowtie,
etc.
If you read on a regular basis (even things you dont need or have too much interest in), you will be that much more knowledgable when something goes wrong. And it will ;)
Today I learned some info on rr's and valve springs!
