·I have noticed that the front tires on my 95 9C1 are wearing on the inside(275/40/17s on Impala wheels).....I know...big suprise! The specs that the front end shop gave me are as follows:
Camber 0
Caster 4.3
Toe 0
Cross Camber 0
Cross Caster 0
According to the specs that I found on here:
Front Camber -0.25
Front Caster 4.00
Front Total Toe 0.00
Front Cross Camber N/A
Front Cross Caster N/A
It appears that I need to change the camber and caster....is this causing the inside wear? Also, I have seen posts that I need .5 cross caster and that I should have 1/16" toe-in. Is the toe-in figure total toe-in or each side? I want to be sure that I get this done correctly this time. TIA
Camber 0
Caster 4.3
Toe 0
Cross Camber 0
Cross Caster 0
Front Camber -0.25
Front Caster 4.00
