Ok I need someone to help me understand this if I was just adjusting front passenger wheel . Let's say I wanted to adjust the wheel to toe in that's going toward driver side which way would I turn the sleeve . I'm saying this because it looks like the sleeve screws on both side of tire rod so it's kinda confusing . So if i twist sleeve which side of tie rod is it pushing or pullingIF the total toe is known to be OK,
You turn the sleeves the same direction looking at the car.
As in both down at front , or both down at rear.
The way to think of this, is turn the wheels to go where the steering wheel is pointed.
If ,say, the steering wheel is pointed to the right when driving, then you need to toe in the left and toe out the right
Then the car will go right like the steering wheel and you will turn back to center to make the car go striaght.
Small adjustments make big differences.
1/4 turn is a lot, 1/2, a ton.
Figure the direction you need to go in and turn the sleeves in that direction before loosening to take up rotational slop in tierods before starting.
Mark sleeve and tie rod intersection so you are turning both sides identical amounts.
This all works fine is , as I said before, only if the total toe was right before.
If the wheel is off, then either something has altered the toe, or a crap WA was done and your toe is questionable even if you have a glossy printout from the guy who couldn't do the job right.
No I only need to adjust passenger front. I need to toe it in. I just don't know which direction to turn the sleeve because of how it looksTurn both left ,and right the same amount in the same direction. If condition worsens ,turn adjusters in opposite direction until satisfied,
It looks like if I turn the sleeve it will pull one end and push the other end if u know what I meanTurn both left ,and right the same amount in the same direction. If condition worsens ,turn adjusters in opposite direction until satisfied,
Toe is not your problem. You have either a camber of caster issue. You should check your shims to see if any have fallen out. The nuts are known to loosen, and allow the shims to disappear. You may also have one or more failed bushing(s).Thank you guys I'll make sure to do it all I said the passenger because the driver is dead on straight. the steering wheel is as well now the passenger is cocked right and when I drive it pulls right and I have to pull the steering wheel left to drive straight if I pull that wheel straight because it's causing me to pull right and me to adjust by turning left it makes sense I've lined up my own cars before . And no it's not any in even wear cause the tires are new and the car hasn't been driven really at all .
