1 - 10 of 10 Posts
Hey guys I just bought the moog problem solver tie rod ends, Im wondering since I dont have a pickle fork is there another way (safe) to remove it?? Thanks guys
You can go to autozone and borrow tools with a deposit. You get your money back when you bring back the tool. I did that when I replaced the suspension in my truck.
I can vouch for this method. My GF's dad showed me this trick when I did my balljoints. Just back the nut off and smack the knuckle on the side with a 3lb sledge (may take a few smacks) and the tie rod will literally fall out.
Hit it with the hammer for sure. Works for me every time. This method works great for when you don't want to replace the parts too, like on a spring install.
Discussion Starter · #9 ·
Now on a slightly different note, does anyone have a good, foolproof method for taking apart ball joints (upper or lower) WITHOUT using a pickle fork/destroying the grease boots? That's why mine were shot. I had opened up my front end at least twice, trying different springs, and the boots took a pounding. Yeah I know about the LCA bushing version of that job but let's assume that isn't an option. When I did my ball joints recently, I DID need a pickle fork to separate the stud from the knuckle, in spite of pounding.
1 - 10 of 10 Posts
