A friend just totalled a `02 TA WS-6. Does anyone know if those swaybars would fit a `95 SS? Let alone anything else that might better the stock suspension?
Thanks,
Eric
The 4th gen f-body suspension is totally different from the b-body.
Wheels won't fit.
Tires will fit (275/40-17) on the Impala wheels.
Shocks probably will fit.
MAF will work with programming.
Some people use the center console in Impalas.
Don't know about the seats (probably not)
Tranny will work with the right bellhousing and some other stuff (it is a 4L60E)
That's all I can think of for now....
I
Is he parting out the TA? If so, can I make a request?
4
for all you jumping on the T56 idea, the LS1 has a diffrent bellhousing bolt pattern and i believe Imput shaft, so Its going to take a bit of time money and effort to get an ls1 t56 in your B body.
