<BLOCKQUOTE>quote:</font><HR>lambdapro
The V92 trailering option includes:
V08 - Heavy Duty Cooling (mechanical fan)
Heavy Duty Condenser
KC4 - Engine Oil Cooler
KD1 - Transmission Oil Cooler
KG9 - 140 Amp Alternator
GW9 - 2.93 gears
G80 - posi<HR></BLOCKQUOTE>
Mine came with....
V92...Trailer Provisions
V08...COOLING SYSTEM, HEAVY WTY
KC4...COOLING SYSTEM, ENG OIL
F40...SUSPENSION SYSTEM, FRT, RR, HD, VAR I
GU5...AXLE REAR, 3.23 RATIO
G80...AXLE POSITRACTION, LIMITED SLIP
JA2...BRAKE, HEAVY WEIGHT DISC DRUM
JM4...BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
K60 GENERATOR, 100 AMP
I guess if we get enough of these lists generated we could eventually boolean the trailer codes....
