I only added the lowers and went with Metco. These are heavy duty and noisy.erc erc erc we have to grease em every other week.
1.93 60' times with a bad differential,
Im planning on getting another set for our 94 caprice. they are sweet!
good luck
96 BBB best 1/4 13.20 @103mph Ed Wright PCM, LT4 hot cam, Extreme timing set & ESC module, GMPP 1.6RR with crane springs, rammit, FLP headers, hooker cat back, meziere H/D H2O pump, s-10 converter, TCI H/D servo, 160* stat, 3.73 gears, msd 6A 8.5 wires, NGK tr55, f-body MAF, metco lower arms, eiback rears springs, GM deep trans pan, airfoil, asp pulleys, t/b bypass, hoosier quick time pro DOT for the track.
94 B4U caprice s&b filter, LT4esc module, msd coil, glasspacks, 160* stat, T/B bypass and 15"AR rims
[email protected]
