·curious what your guys thoughts are on this vibration problem.
1996 LT1-ODB2 (duh), stock tranny, stock TC, aftermarket intake, shorty block hugger headers. Rebuilt stock 4l60e tranny (bad pump)
While in motion under load (leaving a light), I get vibrations through out the car.
Once at a reasonable RPM, it starts to smooth out.
Once at a higher RPM, vibration comes back, but much more mild then from the light under load.
I can see the crank dampening pully vibrating very slightly at idle and through the first 1K of RPM. The thing is, it is visible (maybe .1" runout (maybe 1/16"))
So, I place the car in Neutral, and the vibrations are still present, and in relation to RPM.
I've taken the three torque converter bolts off and spun the TC into all three positions. This may have helped, or may have been a placebo effect (i *think* it changed, but it really didn't).
I've used search and noticed that a few folks mention removing the accessory belts and running the motor like this for a bit. Is it dangerous to do? Can I go for 5 minutes on just the battery like that?
This will confirm its the A/C, P/S, or alternator, right? (oh, Alternator is 'new' AutoZone rebuild).
All fluids are checked and up to spec (color/smell).
I'm trying to narrow this down to either the accessories or the TC.
Is there anything in the transmission that would cause this vibration while in Neutral?
Please, ANY single mild or wild guess would be helpful as I battle this problem.
Thanks SO much guys!
