Change the radiator out and do all that.Just wondering how much Trans Fluid am I going to lose when changing out the radiator? Should I add a qt?
If you are careful you will loose nearly nothing. Make sure to plug the disconnected lines with something so the lines would not get contaminated. You will loose more motor oil if you have a cooler in the radiator.Just wondering how much Trans Fluid am I going to lose when changing out the radiator? Should I add a qt?
