when you first drive the car it won't shift from !st to 2nd unless you let off the gas then it will shift. also having a problem with a check engine light after you drive the car for about 15 or 20 miles, it will begin to shutter and run very rough. it will run rough for about 2 to 5 miles, then throw a check engine light, and the volt gauge will drop very low when this happens. after the check engine light come on the gauge will go back to normal. after a while the check engine light will go off and the car will run normal. wondering if anyone has had this problems before
thanks
