1 - 9 of 9 Posts
ok I need a little help I just bought a 1995 roadmaster 5.7 with a bad tranny no reverse.
My local junkyard has a 2002 chevy 1500 4.3 tranny can I use that in my roadmaster low miles? or would one of these be better???
98 Chevy 2500 5.7 2wd
95 s10 4.3 bellhousing built on with a k on it but high miles
97 chevy van 5.7 bellhousing built on with no letters on the bellhousing
I don't mind swapping simple stuff around like inside wire harness or servo
I was going to order a corvette style servo.
Thank you
i did read the sticky but I did not see any info on late model trannys
thank u for the info
I guess i'll go for the 95 s10
the tranny i'm going to go with is a 1995 chevy 3500 van with a 4.3 motor and a 4l60e with a k on it.
thanks for the help
i will make sure it's a 16 bolt pan. Yea I never would have thought a one ton van would have a v6 4.3 and 4l60e tranny.
thanks for the heads up
1 - 9 of 9 Posts
