Guys,
my front pass window broke the front roller, so the window did a nose dive and made the shark fin when i rolled it down.
i bought 2 of the doorman #74444 the white round thingy.
it was real hard plastic, i thought it would be rubber...anyway...
now my window is really screwd up and need help.
i tried the tips in the roller sticky, but not sure where i went wrong ?
i got everything apart and access to the broken roller.
i put some WD-40 on the white roller and pressed it into the track.
I got a 2" C-clamp and pressed the ball stud into the white roller.
(this was almost impossible to do as angle was crazy hard to get at)
so NOW i have assembled and made sure the window was lined up in the door channel and tried to test it.
The window won't go all the way down, or all the way up... !!!!???
i can not figure out what is binding, if i did anything wrong...?
the rear arm is still OEM and it slides in the track, the new doorman part how ever seems to REALLY SUCK !! it does not move much at all ! the window just moves some and the front arm with the new part barely moves... is WD-40 not slippery enough?
WTH did i do wrong guys !!! i need MAJOR help, need my car to be drivable !!!!
-ALF out....
-ALF out....
