1996 Caprice 9c1, 2018 Ram Laramie CC 4x4 EcoDiesel , '03 Ram 3500 Laramie Sport QC 4x4 Cummins
My car has been sitting for a couple months while I took my time installing a Z28 cluster and adding some sound matting. I took the car on a test drive to see if the Z cluster is where I wanted it. I noticed that I had a check engine light on,got home and pulled a P1661 code. I believe its a MIL Control Circuit according to my cheap ass code reader. Since I loaned out my FSM to a friend who is out Moose hunting,I'm unable to do any reading up on the subject. I also think my trans is shifting a tad funky,harder then usual and it also downshifts into first by its self around 2 or 3 mph. I'm wondering if the code is causing the trans to act up or I have 2 different issues. The only mods I've done with the car is a cold air intake,air pump disabled and a custom tune by Brian.
What say you?
You are correct about the code. Does the CEL come on when you turn on the key? If not, check the bulb and your wiring. I believe this code will cause the PCM to operate in 'open loop' mode full time, which is probably why your transmission is operating funny.
Oh ya the light comes on with the key. I went ahead and reset the code to see if it gets tripped again. Whats weird is the car had no problems when I parked it,and now after the Z28 install,I got the check engine light.
Anybody have a clue where to start looking? I started the car after resetting the code and it comes back. I haven't noticed any lose of power and seems to run just fine.
was the harness for the cluster made right? may have a problem with the cluster, considering it happened after the fact
As far as I know it was made correctly. The cluster was purchased from a forum member and he does sell a bunch. All gauges and lights work.
