1 - 9 of 9 Posts
Anybody ever done this? What systems are out there? Can I use a Dynomax cat-back from the Impala SS?
Thanks,
Chris
P
think you need a 94-up crossmember with 2 humps, the 91-93 ones dont have that.
pat, u r right.. 24 bucks from GM also you need a special tranny tail shaft to fit that crossmember...you also need to weld 2 inches of steel onto your frame to bolt the cross member up... the tranny shaft is factory 4l60.. 94-96 trannys. the tail shaft from gm is over 100 bucks...good luck finding one at a wrecking yard.
Steve S.
93 9C1
88 9C1
P
screw that
ill use the double hump x member from my 71 - same width +/- 1/2", and i have a torch, drill, and welder. i can make it fit!
<BLOCKQUOTE>quote:</font><HR>Originally posted by CAPRICE9C1SS:
. . . also you need a special tranny tail shaft to fit that crossmember... the tranny shaft is factory 4l60.. 94-96 trannys. the tail shaft from gm is over 100 bucks...
<HR></BLOCKQUOTE>
Why would you change the tailshaft on a 700R4/4L60 to a 4L60E tailshaft? They should be the same. Or do you mean tail shaft housing? Please clarify.
PS: Check out
http://home1.gte.net/res05gmd/caprice/faq.htm##6 Dual Exhaust
For info on how to REALLY do it clean. . .
Kelly 'GhoSSt' Rosato
[This message has been edited by GhoSSt (edited October 27, 2000).]
yes, ghost, my bad..the TAIL SHAFT housing will need replaced to fit the 94-96 crossmember. Sorry for the confusion
Steve S.
93 9C1
88 9C1
So why did you feel it (the tailshaft housing) needed to be replaced? I think the tranny mount is the same, please feel free to elaborate. (Enquiring minds wanna know.
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
I have not done the mod myself yet. I have read MANY articals on this subject. Also I purchased a 94-96 crossmember and it would not fit the transmission or the frame. So thats why I said you need a diffrent tail shaft housing. Some articals I read say that you can modify the housing.
Steve S.
93 9C1
88 9C1
<HR></BLOCKQUOTE>
I know that you have to add about 2 inches of flat iron to get teh crossmember (94 - 96 dual hump) to mount, but this is a first on modifying the tailshaft housing or tranny mount problems. Can you post some of the articles on this issues that you've read, I'd like the info myself.
instruction."
1 - 9 of 9 Posts
