my motor went up when I opened the trunk. But when I latch it, it doesn't pull it down... Sad
When I got the car the motor was disconnected and broken. I sourced one from the JY from an 82K Caddy and it worked fine for the last 2 months.
Saturday I used the trunk no issue. Later in the afternoon I put my bag in there and it wouldn't close. I was about 70 miles from home and figured, it was latched although not 'seated', so after 3 or 4 tries I got in and drove. I stopped 2 miles away for a drink and when I got out it was closed.
I proceeded on my way and when I got home, opened it to get my bag out. It worked fine.
This morning I opened it and placed an item in and it closed fine. After work tonight, I opened it and it wouldn't close again.
Okay at least I'm home....I still had the broken one so I figured I'd just swap it back in until I could figure it out.
I had a crap day at work and was hurrying in the dying light.....and I plugged it in....So now the broken one extended. I tried closing that one but it's broken and wouldn't pull down.
I know I have voltage as the old one extended.
I don't know if the one I have in there is bad or if there is an issue with the reverse voltage to pull it down.....
I treied taking the broken one apart to manually lower it to no avail...... FSM was not helpful Sad
Luckily it won't rain tonight so even though it's latched it's still partially open.
Other note: Tonight the trunk ajar light was on while I was driving. Don't recall if it came on or not on Saturday....
