Anyone have underhood pics of the turbo installs? I was wanting to see how others layed their systems out. Trying to get some ideas before i start building.
was your imp DGGM?
Bad idea.Those look pretty good. I'm just gonna run a single turbo. Plan on mounting it between rad and motor.
Thats the car he bought the turbos out of. His car has always been DCMwas your imp DGGM?
yep til u paint it soonThats the car he bought the turbos out of. His car has always been DCM
I was planning on installing a BeCool alum rad with different fans to improve the clearance a bit. How would the fans pulling air thru the radiator be ineffective? All pipes will be heat wrapped to cut down on the heat in the engine bay. Just curious to your thoughts.Bad idea.
service will take forever
you will heat the crap out of the engine bay
Fans and radiator will be ineffective if your making good power
I would put a single were the battery or PCM live and relocate some items.
Wow I am kinda interested in some turbos now... I do like the piping on this set compared to the others I have seen over the years. But is there a way to make it less noticeable? I am thinking more like Chicayne? Would it be possible to move the turbo's from the top of the engine, and move them more towards the front? or where the inner fenders are now?it's changed a little since the picture was taken... no more MAF now cwm1
still a work in progress, I might make it look good during the winter... maybe
Never afraid !!!!!I guess you could do it if you moved the alternator on the lower driver side of the engine and aren't afraid of alot of custom work![]()
a kit? no idea... pretty sure you'll have to fabricate your own.Does anyone know where i can get a single turbocharger kit from????![]()
sure! how 'bout you open that hood? cwm1Does anyone now where i can get measurement to fabricate my own kit???
