1 - 1 of 1 Posts
I just had some work done to the front end of my car. Replaced bent upper control arm, spindle, rotor, bearings(inner and outer), and seals on the front drivers side. The work was done because of a wheel and rotor seperating from the spindle.
Now my question is it possible that damage could be done to the steering rack that may cause the car to have a larger turning radius to the right side when compared to the left side? Its only noticeable when trying to turn right into a turning space. If its possible what would have to be done to correct it?
Thanks In Advance.
1 - 1 of 1 Posts
