P
i just recently put in an indash tv, and ps2 on my daily driver, i also have 2 infinity 4x6's and 2 infinity 6x9's hooked into a memphis gold 4 channel amp. my problem is, sometimes the sound coming out of the speakers sometimes faeds away and i have to power down the tv and power it back up again in order to get the sound back, but it will happen again after that, but sometimes it runs fine? what could it be???
P
anybody?????? i think its the amp but i would like to hear suggestions from you guys!!!!
X
you should really think about putting a bigger alternator in. check your connections. and what kind of wires are you using?
K
I can help, but I need more info. Is you car running when this happens or is it turned off? Does this happen at full volume or? Does this only happen with the TV on or head unit only or PS2 or? What kind of TV do you have I.E. is it built into the headunit or is it seperate. How do you power your TV, is it AC with a converter or is it DC powered? Also what are you using to power your PS2?
P
well im sorry i never reposted to tell everyone i figured it out, it was the amp, i dont know why because it worked with another car afterwards, but i put a new amp in and its fixed now!!! thanks for the replies
