My point in respond to your thread was not to crush your dream of doing this. You could shift the twin Screw forward when you build the intake to clear the cowl. My point to the comment about Hogan or anyone else was they not going to have knowledge of what the issues are so unless you have it figured out and tell them exactly what you need or you will get a design that doesn't work for you. They have no idea what its going in and even if they knew it wouldn't really mean anything to them. They do race cars and in racing if it doesn't fit then cut a bigger hole
Now the problem with shifting the twin screw forward is that also moves the drive shaft futher out and the pulleys/belt may not line up anymore. Thats what I mean by you have to figure out all the details before you ever start.
The comment about just using a LS engine could be the best way to go. It's a package that already has been in production so nothing for you to figure out. You said you were going to use an LS computer so that could be flashed with the stock LS program for the blower model of engine they have. So you could do that if you know how to wrench. Small issues like exhaust and and a few other things but that would be a much easier project than a one off LT. But you need to check the height of that LS engine with the supercharger on it and make sure it will clear your hood. I don't know the answer to that off the top of my head.
It does take everything else I said but could be done on the LT. One off's are cool but it does take a lot.
Not trying to talk you out of what you want but also hard to say nothing and let you spend a bunch of money before you understand what your in for this project. Maybe go the LS blower version is the best answer.
Hope thats a helpful answwer.
