·I'm looking to make my new 9C1 the ultimate sleeper and when I'm satisfied with its performance then I'll go ahead and make it look badass too.
That said, for an ultimate handling setup, I know I need a 32mm F-body front bar, and the HA rear bar.
I already have 9C1 body bushings factory installed, but are they succeptible to wear? The car has 114K on it now so the bushings have 114 k on them too. If there are better ones that can be swapped in then I'll do that.
I have a Moog problem solver idler arm in there now, and plan on Mooging the rest of the front end really soon. Are there any specific parts for the front end that aren't Moogable and if so, what is the best I can do to them? Is there anything better than Moog for any sepcific parts from an ultimate handling standpoint (not worried about longevity, I can live with replacing stuff now and then).
I don't know if my 96 9C1 got the 5/8 or 9/16 balljoints, but I plan on replacing them anyways, and I will make sure they are the 5/8 ones. Can I simply machine the parts to accept the bigger balljoints, or do I need to replace them with the TSB parts? Is there any way to tell if it already has 5/8 balljoints short of taking stuff apart and measuring?
What are the best lower control arms to handle the HA bar out back? I don't want them extended, I want stock length, then I can keep the stock upper arms. I also want to go with the best noise free bushings and everything else for the entire suspension, front and back. I will gladly crawl under the car every so often and grease everything, so if that is a stipulation in keeping some of the parts noise free, its fine with me.
On to springs. I have decided on stock Impala SS ride height. I am planning on the Global west front springs which I understand will keep the stock ride height. What rear springs should I go with? I know the Caprice wagon springs are stiffer than the SS springs, but are they the same ride height?
For shocks I am either going to go with Koni adjustables of the HAL adjustables, I haven't decided which ones yet. I want adjustable so I can switch from handling to launching for a drag race without too much effort.
The tires is the point where I have to sacrifice ultimate handling for reality. I need to drive this car in the winter, I need to drive it on snowy days, through slush, heavy rain, I need all season rubber. I am going to stick with stock Impala SS rimSS. I am planning on either 275/40 or 285/40 whichever is more realistic and conducive to handling. Any reccomendations here, I don't have time or willpower to be swapping tires at the end of a season, so I need something that can handle winter. Even if they aren't superb in the snow, I can get by, I know how to drive a car in the winter. I mean lets face it, 275 or 285 tires are gonna suck in the snow anyways because they're wide, but I'd like the tread pattern and rubber compound to be a bit better than RE730's for the snowy season.
I also have to overcome the 9C1 axle. The rear track of my 9C1 is not quite as big as the rear track of an SS. I plan on doing wheel spacers to move the tires as far out as possible without risking them hitting anything on a major bounce or causing any unnecessary wear on axle bearings. The front track is fine with me for now. Extending the rear track should make the car handle better and will definitely make it look better. What is the best way to go about doing this, including the spacers and studs?
If I missed anything that will help please let me know, and if you know the answers to any of my questions please let me know. I'm off to do some research myself if I find any of the answers before getting a response, I'll post what I found.
Thanks everyone.
Thanks everyone.
