I searched the forum and didn't find much, so...
My '94 9C1 sits higher on the right side - front and back. I swaped back springs - no difference.
I'll try to re-index the front springs and see if that makes a change.
I've read that bad shocks will not raise the suspension, but can a bad shock lower it? In other words, if my shocks are going, is it possible the front left shock is holding the front end down?
Any other ideas to look at?
TIA
Check your balljoints. If they are coming loose (specifically, your left front lower here) it can cause the symptoms described.
