·I emailed ChriSS and George the following, but am posting also to see who else may have some advice on what else to consider. A new fuel filter will go in tonight:
I did a couple of tests yesterday evening and the results have me a little concerned.
I ran the 35/20 jet combo (50 shot), and O2's started in the high 800's and ended up in the low 800's after 10 seconds. On motor only, they stay in the high 800's.
Next, I stepped up just a hair, running 38/22 jetting (75 shot recommended is 41/24). O2's started around 910 and ended up in the low-to-mid 800's after 10 seconds.
I pulled 1 deg of timing for the 50 shot and 2 degrees for the 60? shot.
Looking at DataMaster, and assuming 10 samples per second, NA time from 55 to 100 mph is 7.8 sec. With both jet combos I tried, 55 to 100 was 6.3 sec. That sounds too good to be true - what's up with that?
The 2 degrees was probably too much to pull for the 60 shot. Bryan has me running only 34 degrees total timing NA.
I pulled the #3 and #4 plugs after the second run and after driving about 5 miles home - The porcelain insulators are WHITE! If you imagine really hard, you can see a hint of gray/brown on the #3.
Scary!
Tell me what you think.
I'm running the Walbro 255 and the NX 30 psi fuel pressure switch. My fuel pressure is set at 42 psi.
Now I wish I had a place to plumb a gauge in there. It sure seems like the fuel pressure is dropping. It does not drop even a fraction of a psi on NA runs.
I'm going to replace the fuel filter today.
Bottle pressure was between 1000 and 1050 at the beginning of the runs (full bottle).
