So I added some newer coolant fans a while back (some blue, light weight fans) & that’s when I messed up … both fans died from what I can only imagine the amount of heat my 5.7 created was too much for the soul of those fans could bear …
If you are still using OE fan-on thresholds, lowering them will probably help them (and everything else underhood) last longer.
Actually, did you upgrade the wiring?
A TSB for the fan wiring was only applied to 9C1s.
Correct me if needed, but I think it only applied to the electrical 240W secondary fan's wiring?
However, Fleetwoods moved BOTH relays outside the relay box by design.
Z09B4U corrected my error: it was the PRIMARY fan wiring.
Check for 'meltiness' inside the relay box underhood, under the fan relays.
Even without any 'meltiness', relocating the fan relays outside the box is a precaution.
If you see anything 'melty' when you unplug the fan relays, relocate the fan relays outside the box.
My question to the masses is this what fans are compatible with the 96 caprice / impala’s? Electric fans of course, but I want to go with the OEM size fans …
Every Caprice RoadMaster and Fleetwood that came with an electrical primary fan came with the same 150W electrical primary fan.
Every Caprice RoadMaster and Fleetwood that came with a MECH primary fan, got a 240W secondary fan.
A 240W secondary electrical fan also came on '94 and '95 9C1s, but '96 9C1s got a mere 100W secondary fan.
