Just receive from ebay upper rear arm and measured distance between center of holes.
I get 288 mm what NOT correct for that part#.
283mm is correct according to parts catalog.
So, what's wrong with arm? Or maybe my measurements incorrect?
Wood Tool Font Bumper Automotive exterior
Wood Font Hardwood Automotive exterior Metal
Tool Bumper Font Automotive exterior Auto part
As you say that number is supposed to be 283
I might be stating the obvious,
When measuring , because the two holes are different dia you can't just go inside to outside .
Measure outside to outside PLUS inside to inside DIVIDED by 2.
IF they are indead wrong and difficult to send back due to your local , modifying them would be simple matter of moving the axle end the 5mm.
Weld washers on in the correct position then file the hole.
Well, if you are putting in a pair , my recommendation,
Make sure they are the same ( the pair )
Compare to the original arms length.
Either ,
• Just put in and try ( worst MIGHT be harshness on accel )
• Go through all the crankshaft- driveshaft- pinion angle checks to find the optimal arm dimension
• Modify the arms by stitching washers on and move the holes.
There were actually 3 different upper arms. One was zero which was the standard length and then there was a Plus arm which was a tad longer and then a minus one that was a tad shorter. So the issue might be they put the wrong number on them thinking they were all the same. I forget the exact amount that they were longer and shorter but it was not much.
Mike--Hamilton Chevy
