Honestly this has nothing to do with my car but is a pretty generic question.
Would a leaky valve stem seal cause a spark plug to turn black in under 30 minutes of idling while still compression testing just fine at 90lbs?
The other 5 spark plugs are proper color.
Asking here cause the truck forum is slow to approve new members and a search of their place turned up nothing. (And they don't have a crash to blame it on.)
- Brian
90 pounds sounds a little low? What is the factory specs for compression?
I would not think the seals alone would cause this...maybe if the valve guide was completely shot.
1996 Caprice 9c1, 2018 Ram Laramie CC 4x4 EcoDiesel , '03 Ram 3500 Laramie Sport QC 4x4 Cummins
I concur,sounds like guides and seals. Be sure and let us know what happens after you toss in the new seals,I'm kinda curious
Well, pulled it apart farther, flattened cam lobe caused the number 2 exhaust to open maybe a hair. On with the truck forum now so I'll be search cams and such over there now. Don't worry I still have the conglomerate of various cars loving referred to as the Impala, which is now delaying its paint shop visit because the truck decided to die.
