I found some old pics that may be helpful if others were curious or wanting to replace the hoses on the Charcoal/Vapor Canister. While there are numerous threads on this topic, thought it may be good to post some pics of the canister on the car before removal and how the hoses are connected along with a pic off the car.
It can be easy to overlook this item due to its hidden location. Maybe not so much hidden but definitely not a part you see or look for since it is tucked away up inside the RF Fender extension/filler panel and mounted to the Frame Horn. This panel is the Black Plastic part the lower Right Air Dam attaches to and is mounted between the Bumper Cover and the Fender Wheel Well/Trim area and needs to be removed to gain access.
If you replace these hoses, the type of hose used is important since this is Fuel Vapor being filtered. Factory hoses are most likely non-existent so your best bet may be to match up the hoses and buy length of hose from the Parts Store .At least this is what I did and there was approx. 3 different Hose sizes used.It will be obvious once you remove the canister assembly and Hoses from the Frame Rail.One word of advice, wear gloves when removing the old Hoses to match up as they will most likely be a sooty mess on the outside of the hose.Also use hose that is rated for Emissions or Fuel Vapor and make sure the inside diameter will fit snuggly on the Hose Fittings.
This is a pic of the canister mounted on the car with the front clip removed for visability and to give you an idea of its location. The Canister has a Red Shop towel sitting on it.
This is looking up at the Canister after the panel was removed. The 2 metal lines that the Rubber Canister Hoses mount to go to 1) The Evap Solenoid Mounted on the Intake Manifold and 2) goes back to the Gas Tank Vent. Also notice the little hose (smaller Diameter) going to the check Valve.
This other angle pic shows the 3/8" hose on the right going up into the fender well. This hose does not connect to anything and vents to the Atmosphere. All the cars I have seen have this hose just laying up in the fender well and resting on top of the Wheel House, while others have seen this hose laying in the Battery tray area. Which is correct? I would say run it the exact way you found it although IMHO it seems to be better located in the fender well.
Lastly, here is a Pic of the entire assembly as I removed it from the car and was able to match up Hoses from the parts store. Most Parts places will have this hose on the Spool and sold by foot. Just tell them how much you need and match up the diameters.
