This is what happens when I grab the wheel at 3 and 9 o'clock. Is this play minimal or excessive?
Drivers Side
Passenger Side
Passenger Side Again
Drivers Side
Passenger Side
The idler arm was replaced not even 2 months ago.I see a bad idler arm.
Chris
Yeah good point I watched the video again and I see that it is wobbling.I see a bad idler arm.
Chris
ACDelco....I put a MOOG Problem Solver idler arm on my other B-Body (RMS), and couldn't really tell a difference. That's why I went with Delco on this one.I see up and down movement in the Idler Arm.
What brand did you replace it with? I have had bad luck (parts store parts) with anything that didn't say MOOG Problem Solver on it. Went through a couple cheapies on the sedan I had.
What you need is an assistant--you're looking for motion between the pitman arm (bottom of steering gear) and the center link, when the steering wheel is turned.How do you tell if the center link is shot?
