L
Brandon
You out there!??!?! I greatly appreciate a VIN check on a car that Im thinking of buying...Again! (my 2nd one)
1G1BL52P3SR181819
TIA
L8
N
1995 Chevrolet Caprice Classic/Impala Ss Base Model
4 Dr Sedan
1G1BL52P3SR181819 no records found
N
Carfax will probably say the same thing except it may show it as a government vehicle.
The easiest way to get me to respond is [email protected] . Lucas, you really need to stay off of that "particular" auction site.
That said, here ya go:
VIN: 1G1BL52P3SR181819
VEHICLE INFORMATION
Merchandising Model: 1BL19 - 1995 CAPRICE CLASSIC SEDAN Warranty Start Date: 08/15/1995
Delivering Dealer : KNAPP CHEVROLET, INC.
PO BOX 4179
HOUSTON, TX 77210-4179
(713) 228-4311
CAMPAIGN ELIGIBILITY
95071 STEERING COLUMN TRANSMISSION SHIFT CONTROL ADJUSTMENT N/A Closed
96005 REAR LOWER CONTROL ARM N/A Closed
96010 LOWER CONTROL ARM BALL JOINT N/A Closed
CLAIM HISTORY
12/27/2001 257762 B T2020 - WARRANTY TOWING 159532 miles
12/27/2001 257762 B K7202 - FORWARD CLUTCH RPL 159532 miles
09/22/2000 218971 B N4180 - INST PNL DIGITAL RP 148827 miles
07/12/2000 211859 B N4180 - INST PNL DIGITAL RP 144413 miles
06/02/2000 208196 B N4180 - INST PNL DIGITAL RP 141896 miles
12/20/1999 193923 B F2383 - RING AND PINION REPLACE. 135665 miles
06/24/1999 178876 B J5600 - FUEL PUMP SENSOR 127262 miles
06/15/1998 152484 B K7271 - 2-4 BAND R&R/RPL 99982 miles
05/11/1998 149933 0 K7272 - INPT CARRIER ASM RP 96644 miles
06/25/1997 128007 0 J0100 - RT EXH MANIFOLD REPLACE 72535 miles
06/09/1997 126744 0 K7323 - LOW AND REVERSE CLUTCH PLATES REPLACE 72519 miles
03/26/1997 121673 0 J3480 - WATER PUMP/GSKT RPL 63205 miles
05/03/1996 100868 J V9887 - 96C18 91-96 CAPRICE POLICE/TAXI REAR LOWER CONTROL ARM 28444 miles
05/03/1996 100868 J V9865 - 96C14 LOWER CNTRL ARM BALL JOINT-INSPECT 28444 miles
03/29/1996 098396 # J4206 - SPARK PLG WIRES RPL 24177 miles
02/20/1996 095871 # J4340 - IGNITION COIL RPL 19097 miles
01/02/1996 093015 J V9800 - 95C61B-CAR STEERING COLUMN TRANS SHIFT CONTROL ADJUST 13804 miles
07/03/1995 086118 I Z7000 - NEW VEHICLE INSPECTION ALLOWANCE 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating: 2372 kg (5230 lb) Order Number: 3307VF
Build Date: 06/21/1995 Build Plant: 1SRB - ARLINGTON ASSEMBLY PLANT
OPTION CODES
AA7 AG1 - DRIVER 6WAY POWER
AK5 - SEAT, INFLATABLE, DRIVER & PASS AP9 - CONVENIENCE
ARL - ARLINGTON, TX, USA AS7 - FRT SPLIT
A75 - BACK FRT, HD A76 - BACK RR, HD
BF9 - FLOOR MATS - DELETE B42 - FLOOR MAT, LUGG COMPT, FITTED
B81 - - DELETE C49 - RR WINDOW, ELECTRIC
C60 - AIR CONDITIONER FRT, MAN CONTRO DE3 - LH & RH, REMOTE CONTROL, ELECTR
DL5 - ROADSIDE SERVICE INFORMATION EGW - "DELAYED WARNING"
FE9 - FEDERAL EMISSIONS FLT - OPTION
GU4 - 3.08 REAR AXLE RATIO IHN - INTERIOR DESIGN (HN)
JA9 - HEAVY WEIGHT, DISC/DISC JL9 - ANTILOCK
KD1 - TRANS, OIL KG9 - 140 AMP
LT1 - GAS, 8 CYL, 5.7L, MFI, HO MX0 - 4-SPEED AUTOMATIC TRANSMISSION
M30 - 4L60 AUTO TRANS NA5 - EMISSION SYSTEM, FEDERAL TIER 0
N10 - DUAL/SPORTY EXHAUST N30 - DELUXE
N40 - POWER, NON-VARIABLE RATIO N81 - FULL SIZE
N92 - BOLT-ON N97 - UNDERFLOOR STOWAGE
R4Z - GENERAL R6D - SALES ITEM NO. 04
R7A - SALES ITEM NO. 26 R8S - SALES ITEM NO. 68
UM7 - RADIO - AM/FM STEREO WITH UQ0 - 4, DUAL FRT DR MTD, DUAL STD RG
UQ1 - PROVISIONS, AM/FM STEREO U11 - INST, POLICE, CERTIFIED SPEEDO
U73 - FIXED ANTENNA VK3 - FRT MOUNTING PKG
VM3 - CONSUMER, CONTAINS BPR IMP STAN VQ1 - DEALER ASSISTANCE, WITH HOLDBAC
VZ2 - SPEEDOMETER A V03 - EXTRA CAPACITY
V73 - USA/CANADA WU1 - I/P LP SHUTOFF
YK6 - (SEO) 1AA - RETAIL AMENITIES -- DELETE
1K5 - AUTO TRANS LOW GEAR LOCKOUT 1SA - OPTION 01
1T1 - RADIATOR & HEATER SI RUB 1Z2 - ANTI CORROSION HOT MELT
16U - BRIGHT WHITE 30I - MED DK ADRIATIC BLUE (I) (96)
30N - MEDIUM BLUE VINYL 5AQ
6A2 - (SEO) KEYED 6A3 - FLOOR MAT, FRT & RR, HD
6A4 - SINGLE KEY SYSTEM, NO SPECIFIC 6B2 - RR DOOR, INOPERATIVE
6B4 6C7 - DOME PASS
6C9 - TWO WAY RADIO CONTROL CABLE 6F8 - FRONT DOOR
6H7 - AUTOMATIC TRUNK, RELEASE, LH 6J3 - HEADLAMP FLASHER, GRILLE LAMPS
6N1 - I/S, LH DOOR AND LOCK RELEASE 6N5 - INOPERATIVE, RR WINDOW
6N6 - REAR DR LOCK ROD DEACTIVATION 6SD - COMPUTER SEL SUSP (6SD)
6Y5 - EXTR, EMBLEM, NON-INSTALLED 7B3 - SPECIAL HANDLING
7L9 - STEERING, OIL 7P8 - ENGINE OIL, SEE KC4
7SD - COMPUTER SEL SUSP (7SD) 7X6 - LH, PILLAR MOUNTED, HALOGEN
7Y6 - DOME LAMP, DOOR JAMB INOPERATIV 7Z5 - ADDITIONAL 12 VOLT
8RJ - COMPUTER SEL SUSP (8RJ) 9C1 - POLICE CAR
9RJ - COMPUTER SEL SUSP (9RJ)
:D
L
Brandon
Would saying that its for the Girlfriend make it any better?
These cars are an addiction, Im just glad that I got the little lady hooked as well. She is selling her RUSTANG and we're getting her a 9c1. YEEEHAWW!
thanks for the info!
Lucas
L8
<BLOCKQUOTE>quote:</font><HR> These cars are an addiction, Im just glad that I got the little lady hooked as well. She is selling her RUSTANG and we're getting her a 9c1. YEEEHAWW! <HR></BLOCKQUOTE>
Absolutely! My GF [turned Finance] sold her Nissan Sentra to get a 1995 DGGM 9C1. She liked my blue 9C1 enough to get one of her own. She also likes my 91 Buick wagon so much that she won't let me sell it. She did fuss a little when I got the 95 [civilian] DCM. These are addictive, I'm looking for a buyer on the DCM.
Steve
