Well, last week a small tear on the front of my vinyl top open up on the front, basicaly it started peeling up from the front windshield.
Then list nite I was probably going a little to fast on the interstate and it blew back about 5 inches. So today I go home and figure its gotta come off. Well, origional paint is under neath and looks good. So I pulled the vinyl top back with intentions to take it all the way off, I got back to the rear passenger window above the door handle and realized its not going to come off easy, the rear isnt in that bad shape so I figured I would let it stay. So I cut the front half off, now I have a glue/sticky residue on top.
What do you recomend I do to take it off? Goo Gone? Bug and Tar remover? Anything easier without mutilating the paint? I was going to try and find some rubber molding or something to seal the vinyl top in the rear where I cut it off, any ideas are welcome. I really dont know what Im doing. The picture BELOW shows where I started cleaning up, using my finger nail and a brush that was rough, I think i may have put some scratches in!!!
It was getting dark, oh well it will still look better with that top off, like many things with their top off! ;)
R
I used a pressure cleaner to remove the glue. Piece of cake and it cleans it too! Go to your local self serve car wash. I`m sure they would have one.
Mine pulled off quite easily with very little residue. Goo-gone got the rest.
The difference is that I did mine after it sat all day long in the hot August sun...
HEAT is the key to pulling it off cleanly!!!
Well, one thing working to your benefit (maybe) is that you have an aftermarket top on that car--probably won't, at least from how it looks, have as many mounting holes as a factory one.
I'd hope for some sun & heat, and just keep peeling. The glue & foam should rub off one way or another, just as was said, and it'll look much cleaner in the end, even if the paint is scratched up a bit--a little polishing, and it should be good.
i pressure washed it off, pics coming soon. It looks good, lots of scratches from where they roughed it up for the adhesive, a couple very small rust spots but the paint still looks good.
Now, I just half the back half. What kind of molding/glue/strips should I use to stop the back part from blowing off and making it look some what professional looking.
Im referring to the pic above, the line where I cut if off with the scissors.
