K
Hey guys, I've got an "issue" with my rears; seems that there is "little" sound back there. No volume and no bass. I even replaced the speakers with a set of Pioneers by hooking them up to the stock harness (not installed) with the same results :( Is it my head unit, or is this common with all of the wagons? Also, what size are these speakers?
I want to keep the (a) stock head unit because the crime rate here is WAY high.
As always, any help would be apreciated
U
I can't tell you how to fix it, but I can verify the same problem. I haven't really addressed the issue as I won't be using rear fill.
Hopefully someone else has fixed the issue.
1
same in my impala ss i tried to install aftermarket 6x9's in the rear deck no power so i reinstalled stockers unti, deck unit is replaced in ur case id suggest a cheaper 4 ch amp which with the correct setup can be used with factory head unit
