Anyone have ideas for subs in the rear of my 91 Wagon? The obvious choice is in the 3rd seat area, but I'd like to keep the seat.
Has anyone done a tailgate install? (custom glass panel?)
Driver side wheel well?
Got any pics of your 3rd seat subs? Plexi cover with so you cab see the whole thing?
Just casting about for ideas.
I've got a Rockford head unit and a Pyramid Amp/EQ on the way. Gonna put in Polk EX369's in the back, and most likely matching Polks in the front (as soon as I find out what size will fit in the front doors).
H
My old roommate put 2 10's in a box in the storage compartment in the very back drivers corner. Sounded pretty good. I just installed 2 15's in the 3rd seat area, LOTS of bass!
Yea, using the third seat area as a box seems to be popular.
H
Mine are hidden. I removed the bottom and back of the 3rd seat. Drilled 24 2 to 3 inch holes in the metal, covered it in metal mesh, and mounted a 1/2 inch piece of plywood to the bottom of it. I then mounted the subs to the plywood. They fire up through the carpet and when it is all closed up you can't see anything.
